Episerver Forms Conditional Validation
Currently struggling with a piece of functionality on an Episerver implementation.
Basically I need to implement conditional validation on an Episerver Forms field. E.g. TextBox2 is required is TextBox1 has a value of 1, but is not required when TextBox1 has other values.
I have looked into custom validators but I am unclear how I might extend the validator to have additional properties for the field name I want to target and the value it should have in order for the validation to perform the check.
If anybody has any insight on achieving this it would be appreciated.
#173315
Dec 20, 2016 16:53
Don't know if this is too late for you, but this URL has the info you need:
https://www.wearediagram.com/blog/improving-episervers-content-editing-experience-through-validation
 https://gist.github.com/fredrikhaglund/44d494d04e2ffd4e8cbd
In my case:
public IEnumerable<ValidationError> Validate(HomePage instance)
if (instance.FooterSettings.ShowChannelOne)
if(String.IsNullOrEmpty(instance.FooterSettings.ChannelOneURL) || instance.FooterSettings.ChannelOneIcon == null ||
instance.FooterSettings.ChannelOneHover == null || String.IsNullOrEmpty(instance.FooterSettings.ChannelOneTooltip))
return new[]
new ValidationError
ErrorMessage = "Mandatory to fill out rest of Channel 1 fields (URL, Icons * 2, Tooltip)",
PropertyName = "ShowChannelOne",
Severity = ValidationErrorSeverity.Error
etc....
#173673
Edited, Jan 04, 2017 16:40
