Setup database without any default lanaguage
We are currentl working upon a client site and we are trying to remove the default 'en' or English(American) from the root page.
Has anybody tried this before?
Master Language
Paul
#172194
Nov 25, 2016 15:20
Hi, Paul,
Doesn't seem like it would be easily achievable. What is the business case, what do you want to achieve?
BR,
Marija
#172195
Nov 25, 2016 15:44
Hi Marija
The client would not like the 'e'n to appear as they will not be using this lanaguage branch, they would just like it removed.
I have the database setup and am currently looking at all the references for the 'fkLangugaeBranchID' and swtiching manually to see if that will resolve it.
I am doing this on a clean database to make it a little easier.
Paul
#172196
Nov 25, 2016 15:48
Do you want to switch to another language? Or is it that you don't want the language visible in URL or what?
#172203
Nov 27, 2016 12:56
In Episerver Admin -> Config -> System settings there is an option that says "Enable globalization". If you untick that and save, you shouldn't see language anywhere. Not sure how it works in the DB though, but that shouldn't matter?
#172225
Nov 28, 2016 10:15
