Intercept when SitePage is passed to a controller method
I kind of have the same problem as this person: http://stackoverflow.com/questions/29389926/why-is-the-icontentevents-loadedcontent-event-fired-multiple-times-for-a-page
I basicaly want to intercept whenever SitePage is passed to a controller method.
I tried using IContentLoader.LoadedContent, but if the method is fired about 20 times for each page request then I can't use it.
Can anybody outhere enligten me on the subject?
Here is my code:
[InitializableModule]
    public class LoadedContentEventInitializationModule : IInitializableModule
        //internal Injected CustomPageLoaderService;
            //Add initialization logic, this method is called once after CMS has been initialized
            var contentEvents = ServiceLocator.Current.GetInstance();
            contentEvents.LoadedContent += contentEvents_LoadedContent;
        private void contentEvents_LoadedContent(object sender, ContentEventArgs e)
            var pageData = e.Content as SitePage;
            if (pageData != null)
                //CustomPageLoaderService.Service.LoadPage(pageData);
            //Add uninitialization logic
            contentEvents.PublishingContent -= contentEvents_LoadedContent;
#171690
Nov 15, 2016 10:02
Depends on what you want to do but for example a custom action filter lets you run code before the action is called.
#171705
Nov 15, 2016 15:13
Yeah, I guessed as much. I just thought that there was some better way of implementing it.
Thanks!
This is what I did:
[TemplateDescriptor(Inherited = true)]
    [LoadCustomData]
    public class DefaultPageController : PageController<PageData>
        public virtual ActionResult Index(PageData currentPage)
            return View($"~/Views/{currentPage.GetOriginalType().Name}/Index.cshtml", currentPage);
    public class LoadCustomDataAttribute : ActionFilterAttribute
        public override void OnActionExecuting(ActionExecutingContext filterContext)
            object currentPage;
            if (filterContext.ActionParameters.TryGetValue("currentPage", out currentPage))
                ServiceLocator.Current.GetInstance<ICustomPageLoaderService>().LoadCustomData(currentPage as PageData, filterContext.HttpContext.User);
            base.OnActionExecuting(filterContext);
#171716
Nov 16, 2016 8:56
