Ok, so I finnaly solved this one as well. You need to define what dojo/dijit modules to use to get Episerver to load what you need.
require(["dijit/layout/BorderContainer", "dijit/layout/TabContainer", "dijit/layout/ContentPane", "dgrid/Grid", "dojo/domReady!"], function (Grid) {
If you have this Episerver, or I guess dojo, will load all the files needed.
/Kristoffer
I have built a small plugin that works just fine when the views are placed under Views in my deafult project. To get Episerver to load dojo I use:
If I check the source code after this I can see that Episerver has loaded a ton of script tags like these:
and so on...
When I place everything in modules/_protected nothing is loaded, I can olny see this:
The feeling is that dojo is not loaded correctly so does anyone know how to load dojo correctly from a module?
Maybe I can use Episervers layout file (cshtml) for edit mode or something?
Thanks!
/Kristoffer
