ContentNotFoundException: Content with id 5 was not found
Hi guys. This is one topic that has been mention a few times before, but unfortunaltely all the suggested fixes have not worked for me. I have used couple of days to debug without success and if I am not able to fix it soon I am really considering to start completly new site and build it from scratch. Hopefully somebody had the same problem and solved it.
I am developing a prototype of a new EPiServer website and publish it to a different ISS. The site is MVC and has latest build version 10.0.1.0 of EPiServer.
While I am developing everything works fine, and I have checked my code, there is no ContentReference to an item with the id of "5" anywhere in the routing or cshtml files.
I have recently added plane old indexing service (Not Find) to the site also. It might be realated but I am not sure.
Problem is that I cannot start the site. Right after I open it I get the error massage.
Exception Details: EPiServer.Core.ContentNotFoundException: Content with id 5 was not found
Source Error:
Stack Trace:
[ContentNotFoundException: Content with id 5 was not found]
   EPiServer.Core.Internal.DefaultContentLoader.Get(ContentReference contentLink, LoaderOptions loaderOptions) +622
   EPiServer.Web.Routing.Segments.Internal.NodeSegment.RouteDataMatch(SegmentContext context) +402
   System.Linq.Enumerable.All(IEnumerable`1 source, Func`2 predicate) +163
   EPiServer.Web.Routing.Internal.DefaultContentRoute.RouteSegmentContext(SegmentContext segmentContext) +16
   EPiServer.Web.Routing.Internal.DefaultContentRoute.GetRouteData(HttpContextBase httpContext) +495
   System.Web.Routing.RouteCollection.GetRouteData(HttpContextBase httpContext) +231
   EPiServer.Web.Routing.RouteCollectionExtensions.HandleRouteData(RouteCollection routes, HttpContextBase context) +31
   EPiServer.Global.DefaultDocumentHandling(Object sender, EventArgs e) +181
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +142
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +92
I have tried to use the trick http://mysite/utils/login.aspx to login in and open /EpiServer/CMS but then I get popup every second saying:
Something went wrong.  Failed loading content with the url/uri: epi.cms.contentdata:///5
Also tried to attach the VS debugger but there is no way to break at the exception. I am just able to see that exception is thrown even though I had all exceptions breaks turned on.
Exception thrown: 'EPiServer.Core.ContentNotFoundException' in EPiServer.dll
Exception thrown: 'System.Security.Cryptography.CryptographicException' in System.Web.dll
I have also found some suggestions to look directly into EPi database but I am not so familiar with it so I'll rather wait with that. I can however confirm that in the treeview table there is no item with id 5.
Any help is very appriciated. I hope this is known issue and can be easily fixed.
#171336
Edited, Nov 08, 2016 12:16
Finaly fixed it, with a help from a Epinova consultant.
We opened a tblSiteDefinition table and found two sites there. One of those sites was just a test site with value 5 for the StartPage.
We just updated that value to the the value of the other site and it started working.
Big thanks to EPiServer MVP Dejan Caric,
#171532
Nov 09, 2016 16:57
