Set the default option to enum constant string
I have a string property which allows user to select multiple enum options. I want to set the default option to 'Option1' for the string property.
Property allows multiple selections of the Enum but I want the default option to be set for 'Option1'
[Display(
Name = "options",
Order = 30
[SelectMany(SelectionFactoryType = typeof(EnumSelectionFactory))]
public virtual string Option { get; set; }
Option = Forms.Option.Option1.ToString();
public enum Option
Option1 = 0,
Option2 = 1
public class EnumSelectionFactory : ISelectionFactory
public IEnumerable GetSelections(
ExtendedMetadata metadata)
var values = Enum.GetValues(typeof(TEnum));
foreach (var value in values)
yield return new SelectItem
Text = GetValueName((Enum)value),
Value = value
private string GetValueName(Enum value)
return EnumHelper.StringValueOf(value, true);
#160727
Edited, Oct 04, 2016 18:22
It's a bit odd to have default options checked for a SelectMany control. If something needs to be checked maybe you can combine your SelectionFactory decoration with [Required]?
#160728
Oct 04, 2016 21:57
In terms of funcitonality in the code behind, I could get the option set to the 'Option1' and is working fine, but in the CMS I don't see that option checked. Is there anyway in CMS we can make the option checked?
#160749
Oct 05, 2016 11:14
It's working when I set the default value in the settings of property in Admin mode. I was expecting the code written to set the default value should automatically be picked up without any explicit setting.
#160756
Oct 05, 2016 12:28
Does it work if you just go Option = "Option1";"?
#160757
Oct 05, 2016 12:31
