PlugInProperty as CheckboxList
I am trying to have my plugin have a proprty of a checkbox list to save multiple setting values for my plugin.
I have tried a couple of different ways.
[PlugInProperty(Description = "Tabs to select properties from", AdminControl = typeof(TabSelectorSettingsUi))]
Where TabSelectorSettingsUi is inheriting PropertySettingsControlBase.
I have also tried
public class TabSelectorPropertyControl : PropertySelectMultipleControlBase
I can get both of these to generate a checkbox list but when I try to save I get the same error for both versions:
   EPiServer.UI.Admin.PlugInAdminSettings.Save() +1239
   EPiServer.UI.Admin.PlugInEdit.Save(Object sender, EventArgs e) +21
What did I miss?
Thanks!
/Kristoffer
#170769
Oct 29, 2016 0:52
Can you give little a bit more details about the actual property which  attribute applied to!?
#170809
Oct 31, 2016 10:43
It is actually not a property or well, maybe it is!? :)
I have a plugin for Episerver and in Admin / Config / Plug-in Manager in the Edit plug-in dialog I want to be able to use this property.
It is actually a tab selector property so to speak. The user should connect one or more tabs to my plugin.
Maybe there is a better may to do this? Select one or more tabs use in a plug-in?
Thanks Aria!
#170812
Oct 31, 2016 11:16
I think it is better to have property! If it still doesn't work after that if you can share some of the code and I'm more than happy to take a look :)
#170814
Oct 31, 2016 11:23
So the TabSelectorPropertyControl then is what you mean?
#170816
Oct 31, 2016 11:30
Something like:
 public CheckBoxList SelectedTabs { get; set; }
I'm not sure about backing type (CheckBoxList) ... it could be string and you can store as comma-separated items! Need to try
#170817
Oct 31, 2016 11:46
using System;
using System.Web.UI.WebControls;
using EPiServer.PlugIn;
namespace Episerver75.Settings
    [GuiPlugIn(Area = PlugInArea.None, DisplayName = "Settings")]
    public class MySettings : IMySettings
        private static MySettings _instance;
        public string SelectedTabs { get; set; }
        public MySettings()
            PlugInSettings.SettingsChanged += MySettingsSettingsChanged;
        private static void MySettingsSettingsChanged(object sender, EventArgs e)
            _instance = null;
        public static MySettings Instance
            get
                if (_instance == null)
                    _instance = new AmestoTranslationSettings();
                PlugInSettings.AutoPopulate(_instance);
                return _instance;
using System;
using EPiServer.Core.PropertySettings;
using EPiServer.Data.Dynamic;
namespace Settings.Controls
    public class TabSelectorSettings : IPropertySettings
        public TabSelectorSettings()
            SelectedCategories = string.Empty;
        [EPiServerDataMember]
        public string SelectedCategories { get; set; }
        public IPropertySettings GetDefaultValues()
            return new TabSelectorSettings();
        public IPropertySettings Copy()
            var settings = new TabSelectorSettings();
            settings.SelectedCategories = this.SelectedCategories;
            return settings;
        public Guid Id { get; set; }
using System.Linq;
    public class TabSelectorSettingsUi : PropertySettingsControlBase
        private CheckBoxList tabs;
        protected override void CreateChildControls()
            base.CreateChildControls();
            tabs = new CheckBoxList();
            tabs.Items.Add(new ListItem("Test 0", "0"));
            tabs.Items.Add(new ListItem("Test 1", "1"));
            tabs.Items.Add(new ListItem("Test 2", "2"));
            Controls.Add(tabs);
        public override void LoadSettingsUI(IPropertySettings propertySettings)
            EnsureChildControls();
            var tabSelectorSettings = propertySettings as TabSelectorSettings;
            if (tabSelectorSettings == null)
                return;
            var selectedTabs = tabSelectorSettings.SelectedCategories.Split(',');
            foreach (ListItem tab in tabs.Items)
                if(selectedTabs.Contains(tab.Value))
                    tab.Selected = true;
        public override void UpdateSettings(IPropertySettings propertySettings)
                return;
            var selectedTabs = new List<string>();
                if (tab.Selected)
                    selectedTabs.Add(tab.Value);
            tabSelectorSettings.SelectedCategories = string.Join(",", selectedTabs);
So this is the code example for my test with using settings.
#170818
Oct 31, 2016 12:23
And here is the property example
using System;
[PlugInProperty(Description = "Tabs to select properties from", AdminControl = typeof(TabSelectorPropertyControl))]
        public MySettings()
            PlugInSettings.SettingsChanged += MySettingsChanged;
            _instance = null;
            get
                    _instance = new MySettings();
                return _instance;
    using System;
    using EPiServer.Core;
    [PropertyDefinitionTypePlugIn]
    [Serializable]
    public class TabSelectorProperty : PropertyMultipleValue
        public override IPropertyControl CreatePropertyControl()
            return new TabSelectorPropertyControl();
using EPiServer.Web.PropertyControls;
        protected override bool ShouldCreateDefaultControls()
            return false;
        public PropertyMultipleValue CheckboxListValue
            get { return PropertyData as PropertyMultipleValue; }
        protected override void SetupEditControls()
            SetupDropDownList();
            this.SetupDropDownList();
        protected virtual void SetupDropDownList()
            this.AddItems();
            if (CheckboxListValue != null && CheckboxListValue.Value != null)
                foreach (var value in CheckboxListValue.ToString().Split(','))
                    ListItem li = EditControl.Items.FindByValue(value);
                    if (li != null)
                        li.Selected = true;
        private void AddItems()
            this.EditControl = new CheckBoxList();
            this.EditControl.EnableViewState = false;
            this.ApplyControlAttributes((WebControl)this.EditControl);
            this.EditControl.RepeatColumns = 3;
            this.EditControl.Style["display"] = "inline";
            EditControl.Items.Add(new ListItem("Test 0", "0"));
            EditControl.Items.Add(new ListItem("Test 1", "1"));
            this.Controls.Add(this.EditControl);
Both of my above example gives me:
   EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +125
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +222
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1734
#170935
Edited, Oct 31, 2016 13:05
So I solved it.
The key was to use the AdminControlValue on the PluginProperty definition
[PlugInProperty(LanguagePath = "/Translations/Settings/SelectedTabs", AdminControl = typeof(TabSelectorPropertyControl), AdminControlValue = "CheckboxListValue")]
Make a property CheckboxListValue that gets and sets the value of your property then it works just fine.
/Kristoffer
#171060
Oct 31, 2016 22:31
@Kristoffer: Good one you I just wanted to write down that :D :) but anyway sorry for late response
#171061
Oct 31, 2016 22:48
Thanks for your time and help Aria, I really apriciate it!
#171063
Oct 31, 2016 23:24
