Normally you use the SelectOne attribute to create a dropdown instead
You can probably make a radiobutton list as well but normally not worth the work since the dropdown works just as well...
Output selection using the standard HTML.PropertyFor normally...
How to add radio button in episerver editor view and how it will be called from view
