The solution was that I needet to delete all files in the modulesbin-cataloug before running "Upgrade/disable Add-ons after Product upgrade" in Deployment center. I could then run "Upgrade/disable etc" without errors, and the error above disappeared.
I have upgraded a site to CMS 7.5, and I get the following error when trying to browse the site:
Unable to load one or more of the requested types. The following information may be a subset of the Type/LoaderException information present - inspect with debugger for complete view.
Check assemblies [EPiServer.Cms.Shell.UI, Version=2.1.90.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7] and/or types [EPiServer.Cms.Shell.Extensions.CultureInfoExtensions,
EPiServer.Cms.Shell.Extensions.ExceptionExtensions,
EPiServer.Cms.Shell.Extensions.ExtendedMetadataExtensions,
EPiServer.Cms.Shell.IContentExtensions,
EPiServer.Cms.Shell.IContentVersionRepositoryExtensions,
EPiServer.Cms.Shell.Extensions.SettingsExtensions,
EPiServer.Cms.Shell.Json.BlockDataConverter,
EPiServer.Cms.Shell.Json.ContentFragmentViewModel,
EPiServer.Cms.Shell.Json.ContentAreaConverter,
EPiServer.Cms.Shell.Json.ContentDataStoreModelConverter,
EPiServer.Cms.Shell.Json.ContentDataStoreModelConverter+PropertiesConverter,
EPiServer.Cms.Shell.Json.IContentConverter,
EPiServer.Cms.Shell.Json.UrlConverter,
EPiServer.Cms.Shell.MoveToPlatform.ContentTypeExtension,
EPiServer.Cms.Shell.MoveToPlatform.RoutingInitializationModule,
EPiServer.Cms.Shell.MoveToPlatform.IWorkflowTaskRepository,
EPiServer.Cms.Shell.MoveToPlatform.PersonalizedContentAreaExtensions,
EPiServer.Cms.Shell.MoveToPlatform.PersonalizationContentControlResolver,
EPiServer.Cms.Shell.MoveToPlatform.PersonalizationContentControlResolver+PersonalizedContentRenderer,
EPiServer.Cms.Shell.MoveToPlatform.TemporaryViewEngine]. Information from LoaderExceptions property [Method 'get_DefaultContext' in type 'EPiServer.Cms.Shell.UI.CompositeViews.HomeView' from assembly 'EPiServer.Cms.Shell.UI, Version=2.1.90.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation.].
Exception Details: System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. The following information may be a subset of the Type/LoaderException information present - inspect with debugger for complete view.
Source Error:
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\874b9fd2\d2093bbf\App_global.asax.0.cs Line: 0
Stack Trace:
I have read this blogpost, but can't find any new answers there: http://world.episerver.com/Forum/Developer-forum/-EPiServer-75-CMS/Thread-Container/2014/1/Error-upgrading-to-75/
Any help would be appreciated
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1055.0
