Log in into chat application using default login
I want to login into my chat application which is a javascript app from the logged in credentials of the Episerver. I was just having a look into episerver alloy app. I was not able to find the login page. Please how you help me on achieving this. Thanks is advance!!!!
#143605
Jan 27, 2016 15:25
for most EPiServer sites you can always log in using the url:
[domain]/util/login.aspx
To get the current user and check authentication:
EPiServer.Security.PrincipalInfo.CurrentPrincipal.Identity.IsAuthenticated
and
EPiServer.Security.PrincipalInfo.CurrentPrincipal.Identity.Name
You can use the second to log in the current user to your js app...
#143606
Jan 27, 2016 15:36
Thanks for the reply daniel. I am the alloy app in my visual studio . I was not able to find the login.aspx page in the Solution explorer. I am using active directory to login, I need username and password of the user to autologin into my chat account. Would be suggest me a way how to achieve it.
#143623
Jan 28, 2016 7:10
Hi i am using ejabberg server with converse.js, i need to pass the CurrentPrincipal for authentication.
https://conversejs.org/docs/html/configuration.html#prebind-url
This is how is need to achieve it but how to pass SID and RID.
#143628
Jan 28, 2016 8:05
I would probably do a custom login page for EPi. There are plenty of guides of how to do that. It's pretty easy...
After validating credentials I would store a unique id in session for the user that I can then use as SID and pass to ejabberg server.
For RID I would probably generate a unique id for each request in the ActionFilter that is used to set the overall layout for mvc / masterpage for webforms.
#143634
Jan 28, 2016 10:02
