Broken Embeded Link
I am using a custom API to get a content block from CMS. I am making this call from a seperate website and manipulating a portion of the content. The result is rendering an embedded link invalid. The link's URL doesn't change and I am not manipulating the URL and do not understand why the embedded URL is not redirecting to the right page.
I am very new to Episerver. Please, if possible, frame answers as simply as possible.
#143204
Jan 14, 2016 23:18
Which Epi version are you using and how are you getting the XhtmlString property value that you use in the API result?
#143208
Jan 15, 2016 9:32
We are using episerver CMS 8.2
And this is the code I am using to pull the Xhtmlstring value
message =
MemoryCacheManager.Instance.Retrieve<dynamic>(CacheKeys.ConsentPageHtml)
.[ContentBlockName].ToString()
.Replace("\n", "")
.Replace(baseAddress, "..")
.Replace("60",
[ValuetoReplacePartofTheStringWith].ToString(CultureInfo.InvariantCulture));
#143217
Jan 15, 2016 16:32
To give more clarity in to what I am seeing, sometimes, the value to replace in the string will be "60" so I will replace "60" in the string with "60". In this situation the link works fine. But sometimes the [ValuetoReplacePartofTheStringWith] is "59" or "57" or something, so "60" gets replaced with "59". In this case the link is broken.
Here is an example of the strings"
Content Block in CMS, un manipulated:
"You are 60 days from x, please go to [link] to find out more"
Manipulated string with a replace value of "60":
"You are 60 days from x, please go to [link] to find out more" - Link works fine
Manipulated string with a replace value of "59":
"You are 59 dats from x, please go to [link] to find out more" - Link is broken
It seems if the content around the link is in any way different then the link becomes broken.
#143218
Jan 15, 2016 16:47
I've never seen people fetching HTML off a block in that manor (using CacheManager).
If you instead use the defined property you can do ToHtmlString() on it and then the URLs will be rewritten and consistent.
For example:
message = yourBlock.YourXhtmlStringProp.ToHtmlString().Replace(etc..)
#143220
Jan 15, 2016 17:09
