Widget development
I am enhanching Commerce Catalg UI. and creating a gadget. If some thing goes wrong in script or I update something, It doesnot reflect my latest changes in script.
What I will require to do to get always latest changes in Dojo/Dijit Script? (It looks every thing gets cached)
E.g.
define([
"dojo/_base/declare",
"dijit/_WidgetBase",
"dijit/_TemplatedMixin",
"epi/_ContentContextMixin"
path for _ContentContextMixin is wrong. Now there is no way to remove gadget from UI, as screen will blank always.
Or change
contextChanged: function (context, callerData) {
alert("Context changed" + context.Name);
to
//something else
Regards
Khurram
#139325
Sep 30, 2015 9:51
Dojo script are strongly cached. If you need get files updated every time you refreshed the page, then open chrome Developer Toolbar (F12) and on Network tab mark "Disable cache" checkbox. Notice that the tool have to be opened for all the time. The alternative is to use some chrome extension like "Cache killer".
I hink that path to _ContentContextMixin should be "epi/shell/_ContextMixin" instead of "epi/_ContentContextMixin"
If your gadet break edit mode for user,then  you could try to reset user settings in admin mode. The gadget should be removed from personal settings.
#139326
Sep 30, 2015 10:14
Thanks  Grzegorz, My issue is sorted. (I will mark your sugestion as Answered)
Do you have some other development setup related tips that you faced intiallay when started development in this area?
Regards
/K
#139328
Sep 30, 2015 10:22
It's also very helpfull to turn on debug mode of client resources (I don't know if you already did it)
 <episerver.framework>
    <clientResources debug="true" />
#139331
Sep 30, 2015 10:33
Done, :) , Next...
#139332
Sep 30, 2015 10:36
#139343
Sep 30, 2015 12:24
