I iterate all vistor groups used in my Visitor Group Usage gadget. Take a look at:
For some inspiration.
Thanks for the inspiration. Now i have installed your gadget. I hope my editors will like it. I think it is very helpful.
Thanks to you i now have a code that works. But my code uses currentContentArea.Contents witch is obsolute. Did not find a good solution for that. Do you have a solution?
public override ActionResult Index(SiteBlockData currentContent)
if (PageEditing.PageIsInEditMode)
var currentContentArea = ControllerContext.ParentActionViewContext.ViewData.Model as ContentArea;
if (currentContentArea != null)
var visitorGroupRepo = ServiceLocator.Current.GetInstance<IVisitorGroupRepository>();
//Find currentContent in content area. Any better way of doing this?
int index = currentContentArea.Contents.IndexOf(currentContent as IContent);
var item = currentContentArea.Items[index];
if (item.AllowedRoles != null)
var names = String.Empty;
var counter = 0;
foreach (var group in item.AllowedRoles)
counter++;
var vg = new Guid(group);
var loadedVg = visitorGroupRepo.Load(vg);
if (loadedVg != null)
if (counter == 1)
names = visitorGroupRepo.Load(vg).Name;
else if (counter < item.AllowedRoles.Count())
names = names + ", " + visitorGroupRepo.Load(vg).Name;
else
names = names + " and " + visitorGroupRepo.Load(vg).Name;
currentContent.VisitorGroups = names;
return PartialView(string.Format("~/Views/Shared/Blocks/{0}.cshtml", currentContent.GetOriginalType().Name), currentContent);
View
@using EPiServer.Editor
@model SiteBlockData
@if (PageEditing.PageIsInEditMode && !String.IsNullOrEmpty(Model.VisitorGroups))
<p>Visible to: @Model.VisitorGroups</p>
Any other feedback?
I am trying to render a blocks visitor groups. Anybody know how to do this? Since Blocks will be personalised for every contentarea they are used on. I have created a Ignoe field on the block model that i want to render a string showing the personalization informasjon.
I am thinking that i can get the information i need in the block controller
Anybody?
