Issue with Block Language Translation - Episerver CMS 8
iliyas shaikh
iliyas shaikh
OMVPOpal Tools CertificationPaaS CMS Developer CertificationPaaS CMS Administrator Certificationworkspace_premium
I am facing issue with block language translation on page on Episerver CMS 8.
I have page with ContentArea property on which i put multiple Blocks but when i change page language (for e.g english to swedish) all the blocks get disappeared/removed. ContentAea Property is CultureSpecific and also properties inside Block is also Culture Specific. Also for BlockType LanguageSettings is disabled.
Though its logical that for new language CultureSpecific properties of page will be blank but feel that it should hold for block atleast as its not good idea that editor should create a same block all again for different language. Cumbersome is when you have more blocks on page and for new language editors have to create all blocks again.
Has anyone faced the small problem or have solution for this?
iliyas
#135833
Sep 16, 2015 10:47
Hi, maybe some ideas could be found here: http://cjsharp.com/blog/2013/04/19/automatically-populating-page-or-block-type-properties-for-a-language-branch-in-episerver-7/
I think also LanguageManager AddOn does this. You can choose to create new language branch out of existing language content.
#135835
Sep 16, 2015 11:25
Hi Ilyas,
1. You can add a feature request, but this is a built-in behaviour and very unlikely that this will be accepted.
2. hook up an event handler to LoadedDefaultContent and check if ContentLink is not null or empty if so copy the values from Master language
[ModuleDependency(typeof(InitializationModule))]
public class SetDefaultLanguage : IInitializableModule
context.Locate.Advanced.GetInstance<IContentEvents>().LoadedDefaultContent
+= delegate(object sender, ContentEventArgs args)
if (!ContentReference.IsNullOrEmpty(args.ContentLink))
//For a new language branch will contentLink not be empty
//get master language
//set the value
Regards
/K
#135836
Sep 16, 2015 11:29
Yes, this also is possible, but then - we are loosing flexibility to give editor an option to choose whether to copy content or not, that you can get out of LanguageManager AddOn. Editors are demanding people :)
#135837
Sep 16, 2015 11:34
iliyas shaikh
Thanks Valdis and Khurram for your suggestions. Need to check whether LanguageManager AddOn does the things which i want.
Alternate solution is to have language enable for the blocks same as for pages(For e.g English and swedish) so that editors don't have to create a new one. But in my case languagesettings is disabled by default for all Blocks.
is there any settings to enable language settings for all blocks or am i missing something?
#135860
Sep 16, 2015 12:40
