ContenArea modification does not work
I m trying to modify content area programmaticly, but can not get it work. By hooking save event on episerver, I should be able to modify the content area on savingContent.
this simple logic is to delete content items on contentarea but does not save and refresh backend page.
 var page = e.Content as StandardPage;
            if (page.MyContentArea != null && page.MyContentArea.Items.Any())
                var clone = page.CreateWritableClone() as StandardPage;
                foreach (var contenAreaItem in page.MyContentArea.Items)
                    clone.MyContentArea.Items.Remove(contenAreaItem);
                DataFactory.Instance.Save(clone, SaveAction.Save, AccessLevel.NoAccess);
any help appreciated
#133315
Sep 01, 2015 15:08
Can you please provide full code (interested in part how you subscribe to event)?
#133329
Sep 01, 2015 22:35
Maybe you need to assign contentArea to property
	var contentArea = page.MyContentArea;
    foreach (var contenAreaItem in contentArea.Items)
        contentArea.Items.Remove(contenAreaItem);
	// assign contentArea to property
	page.MyContentArea = contentArea;
#133332
Sep 01, 2015 23:38
[Valdis] : this is the event that u subscribe.  DataFactory.Instance.SavingContent += SavingContent;
[Grzegorz] : yes, you right I needed to assing contentArea to property.
Thank you for your help.
#133341
Sep 02, 2015 10:38
If you do SavingContent (before the actual save) you shouldn't need to save yourself.
If you do SavedContent (after saving has been done) you need to.
#133345
Sep 02, 2015 11:15
I wasn't aware that you need to re-assign CA to the property to get it populated. Weird
#133346
Sep 02, 2015 11:19
That is the most common way I've seen to trigger IsModified on the CA.
EPiServer doesn't care about the value if IsModified is false
#133347
Sep 02, 2015 11:21
I look at CA as observable collection and any modification should set IsDirty/IsModified/IWantToSave/Whatever flag to true, so EPiServer storage engine knows what to do. Thanks for tip.
#133348
Sep 02, 2015 11:24
