For future reference.. I found the solution ... The problem is that i had a folder in my solution called "positionpaper" as well and it looks like you cannot have that and a simple address with the same name...
So hope this will help others in the future as well.
Hey guys,
i have a strange issue. I created a page and want to add the simple address names "positionpaper". The error: "Simple address" with value "positionpaper" cannot be used since the value coincides with the path of the folder "positionpaper"."
I get this error where i cannot find anything about. I know for sure that this simple address isnt in use anywhere else, and even then the error would be different ( i tested).
So why can i not use this name. If i add "position-paper" then it works. If i use this string on any other page, it also doesnt work..
Am i missing something obvious. its important for the client to use the name "positionpaper" because that address is corresponded to everyone..
