Image is not loaded in CMS 8.8
I'm running version 8.8 and I'm not able to load an image from code.
Code below:
[CultureSpecific]
        [Required(AllowEmptyStrings = false)]
        [UIHint(UIHint.Image)]
        [Display(
            Order = 3)]
        public virtual ContentReference Image { get; set; }
and in my view:
Im getting 200 on the image but it is not shown, does this has to do with version 8.8 or is it something else? When I look in firebug the path is correct as follows:
/globalassets/test/myimage.jpg
And if I go to the url:
http://mysite.com/globalassets/test/myimage.jpg
The image is shown correctly in firefox but not in IE. And if I try following:
the image is not shown either.
Any help or suggestions much appreciated.
/J
#131947
Aug 10, 2015 15:56
I would like to add that the image is visible in editmode, but not outside editmode, this clearly feels like an EPiServer bug in 8.8?
/J
#132027
Aug 12, 2015 14:18
Somehow the content type "Image" was set to be rendered by a specific controller that tried to render the image as HTML, reverted to default setting did the trick.
/J
#132643
Aug 14, 2015 15:03
