EPiServer and SignalR
Hello
I tried following this guide:
http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-CMS/75/Configuration/Configuring-NET-SignalR/
But when I got to the part where it said I should install Content Collaboration and Live Monitor add-ons, I could not find them in my EPiServer-interface under Add-ons. They're simply not listed, and not under beta either.
So I instead I decided to add an OWIN Startup class, because I really don't need the add-ons, I just want SignalR to work.
But unfortunately for me, this does not work either:
http://world.episerver.com/documentation/Items/Upgrading/EPiServer-CMS/75/EPiServer-and-OWIN/
The startup class does not fire.
I also installed the Microsoft.Owin.Host.SystemWeb package in case that was the issue.
Here are my assemblt bindings:
Also added this:
But to no avail.
Some code:
[assembly: OwinStartup(typeof(EPiServerSite1.Startup))]
namespace EPiServerSite1{
    public class Startup    {
        public void Configuration(IAppBuilder app)
            app.MapSignalR();
Does anybody know why I can't get OWIN and SignalR up and running?
Latest EPiServer installation (Alloy MVC) under VS2015.
#132671
Aug 17, 2015 10:31
Try to follow this:
http://www.asp.net/signalr/overview/getting-started/tutorial-getting-started-with-signalr-and-mvc
You must install the signalR nuget package and that package might give you a startup file.
Also, dubbel check that you are using framework 4.5 or higher, otherwise it will not work
#132674
Aug 17, 2015 12:37
Yes, I have done all of this, as mentioned in my first post. The SignalR-nuget package is indeed installed and SignalR is running fine under non-EPiServer solutions. The Startup class in my first post does not fire.
#132676
Aug 17, 2015 13:00
To answer my own question: Clearing out the ASP.NET Temporary Files made the problem go away ;)
Thanks Henrik :)
-Emil
#132678
Aug 17, 2015 13:21
Nice that you got it to work!
#132700
Aug 17, 2015 16:15
