Hi Nicola,
Do you have smtp settings defined in web.config:
<system.net>
<mailSettings>
<smtp from="REPLACE_THIS">
<network host="REPLACE_THIS" />
</smtp>
</mailSettings>
</system.net>
Does it work if you save emails on the file system:
<system.net>
<mailSettings>
<smtp deliveryMethod="SpecifiedPickupDirectory" from="no-reply@localhost.com">
<specifiedPickupDirectory pickupDirectoryLocation="C:\SomePath" />
</smtp>
</mailSettings>
</system.net>
Have you checked log files?
I'm struggling to find a solution in the forums about my issue altho this seems to be basic one.
I have an XForm with the following settings:
This form works without any issues. When a user submits the form, the system redirects to a "Thank you" page.
However, when I change the 'Result from sending' property to 'Send e-mail', the ModelState suddenly becomes false with the following error:
The form could not be sent to an e-mail address
I have tried a couple of things:
Both solutions didn't work.
I do know that I have the right IP Address as I installed an SMTP-client on the same server and was able to send emails successfully.
I'm running an ASP.NET MVC application using EPiServer 8.9.
Any help would be highly appreciated!
Nicola
