Try in EPiServerFramework configuration section to use the virtualPathMappings element to override it instead. Make sure the VirtualPathMappedProvider is in the list as well.
<virtualPathMappings>
<add url="util/logout.aspx" mappedUrl="/Accont/Logout" />
</virtualPathMappings>
Hope this helps
Frederik
Frederik thanks for your answer.
I've added this provider under virtualPathProviders
<add name="CustomUrlMapping" type="EPiServer.Web.Hosting.VirtualPathMappedProvider, EPiServer" />
then
<add url="~/util/logout.aspx" mappedUrl="~/logout.aspx" />
It seems to work only if the file extension is the same though.
Is there anything else I can override to use an MVC route?
Thanks.
For anyone else looking this would work:
public class Startup
public void Configuration(IAppBuilder app)
app.Map("/util/logout.aspx", map =>
map.Run(ctx =>
ctx.Response.Redirect("/to/custom/route");
return Task.FromResult(0);
I'm trying to override the default logout url.
I've added a new route to the route collection:
routes.MapRoute("Logout", "util/logout.aspx", new { action = "Logout", controller = "Account" });
Any clues why it is not working?
Luca
