Does Live Monitor and CMO require any additinal config in load balanced environments?
I have installed both CMO and Live Monitor, but do they need any additional configuration for load balanced environments?
I found out maybe Live Monitor did, but that documentation seemed like it was for the old silverlight version of Live Monitor.
#123734
Jul 17, 2015 15:00
For CMO, there is additional config depending on your setup. For example: http://dmytroduk.com/techblog/episerver-cmo-in-load-balancing-environment-with-separate-editing-server and http://dmytroduk.com/techblog/episerver-cmo-in-load-balancing-environment-simple-scenario
As far as the new live monitor (non-Silverlight) and load balancing, our documentation for it doesn't include references to load balanced environments - http://world.episerver.com/add-ons/live-monitor/configuring-live-monitor-add-on/ but the instructions under "Interval Based Updates (load balanced environments)" may still apply - http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-CMS/75/Configuration/Configuring-Live-Monitor/
#131216
Jul 17, 2015 19:56
So, I need to use the development center to install the statistics handler and aggregation service.
We actually have this scenario: http://dmytroduk.com/techblog/episerver-cmo-in-load-balancing-environment-with-separate-editing-server
Thanks for the reply.
It would be nice if anyone knew about the live monitor though, before we went live with it. But I guess it's only in edit mode, so it doesn't matter that much.
#131293
Jul 20, 2015 9:58
I'm glad that the CMO portion was helpful for you. Unfortunately, I don't have knowledge of load balancing for Live Monitor for the new version. My assumption is that load balancing may work the same way like the old version since the new Live Monitor is primarily a UI overhaul - http://world.episerver.com/articles/Items/New-add-ons-available-in-the-Add-on-Store-beta-feed/.
#131307
Jul 20, 2015 19:00
Did you get the New LiveMonitor version to work in load balanced environmnent with a separate edit machine to work??
Livemonitor is working on the editing machine but there is no sign of the visitors on the load balanced machines?
Is there som new documentation, I haven't find one?
#145486
Mar 04, 2016 12:52
I don't really remember anymore. But I don't think I did.
#145488
Mar 04, 2016 13:27
That's a shame, it's a nice tool and it should work out of the box! Our silverlight version worked but then after the upgrade, we just can't get it to work!
#145490
Mar 04, 2016 14:06
