I am performing an upgrade of EPiServer from 6.1.379.0 to version 7.0.859.1.
However, soon after I run the installer I get the following error:
An error has occured and the transaction will be rolled back Rolledback Object reference not set to an instance of an object. Object reference not set to an instance of an object.
An unhandled error has occured: Object reference not set to an instance of an object. When executing At C:\Program Files (x86)\EPiServer\Framework\7.0.859.1\Install\System Scripts\ Install Site (SqlServer).ps1:319 char:4 + New-EPiDirectory -DirectoryPath $packagingRootPath + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
True = Get-EPiIsBulkInstalling
= Get-EPiIsBulkInstalling At C:\Program Files (x86)\EPiServer\Framework\7.0.859.1\Install\System Scripts\Install Site (SqlServer).ps1:319 char:4 + New-EPiDirectory -DirectoryPath $packagingRootPath + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ System.NullReferenceException: Object reference not set to an instance of an object. at EPiServer.Install.FileSystem.Installers.NewDirectoryInstaller.Install(IDictionary stateSaver) at EPiServer.Install.InstallationManager.Install(Installer installer) at EPiServer.Install.FileSystem.Cmdlets.NewDirectoryCmdlet.ProcessRecord() at System.Management.Automation.Cmdlet.DoProcessRecord() at System.Management.Automation.CommandProcessor.ProcessRecord()
error This topic was created over six months ago and has been resolved. If you have a similar question, please create a new topic and refer to this one.
Rolledback
When executing
True
When executing
Does anybody know what I can do to fix this?
