Upgrade issue from 7.5 to 8
Hi ,
Because this is the first time to new thread for epi,I 'm not sure this is corrrect category here.I encountered the following problem after upgrade to 8 from 7.5 as the instruction http://world.episerver.com/documentation/Items/Installation-Instructions/Installing-EPiServer-updates/ ,including refered to http://world.episerver.com/link/3381e12654c04ace971fe8a3d90ae081.aspx?id=115661 ,
It seems to big change style for multi- Languages in edit model,  I think epi support can give good solution for help.
style issue
the element class is ".Sleek .epi-previewableTextBox-text",which is including "max-width:15em" caused this issue.so how can I remove this or should any other ideas?
#121427
May 11, 2015 4:23
update:I find the style setting in EPiServer.Cms.Shell.UI.zip,but should we change that,I think it's not good.
#121472
May 12, 2015 8:09
As far as I know this is fixed inside CMS package. You can try to override this style in your own CSS. Maybe will affect edit mode language selection.
#121523
May 13, 2015 6:36
Thank you,Valdis.currently I have overriden the style to 200em.Hope next epi update to remove that.
#121527
Edited, May 13, 2015 8:54
