Upgrade issue from 7.1 to 7.5 - add ons (Google Analytics )
I am facing issues when upgrading episerver project from version 7.1 to 7.5.
I have upgraded initially using the episerver deployment center and then through nuget packages, I updated the version to the latest version which is 7.19
I fixed all errors except there are few warnings but the project compiles successfully. When I run the project I got the following error related
to episerver google analytics. We have episerver google analytic add on installed on version 7.1.
I have also run the "upgrade/disable Add-ons after product upgrade" but still the same issue as below:-
Does it ring a bell to anyone. Thanks in advance.
The error is :-
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
   EPiServer.GoogleAnalytics.Internal.Services.Accessors.GetTrackerSettings(SettingsRepository repository, SiteMappingConfiguration siteMapping) +0
   EPiServer.GoogleAnalytics.Tracking.ScriptBuilder.ShouldAppendScript(HttpContextBase context) +60
   EPiServer.GoogleAnalytics.Tracking.AnalyticsClientResourceRegister.RegisterResources(IRequiredClientResourceList requiredResources, HttpContextBase context, PageData pageData) +79
   System.Collections.Generic.List`1.ForEach(Action`1 action) +14454519
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4627
#121313
May 06, 2015 16:10
Hi Nazim,
It looks like you still have GA 7.1 binaries in your project? You'll need to update your GA add-on to versions compatible with 7.5 or else you may come across issues with your project.
#121333
May 06, 2015 18:34
Thanks Richly, I have tried adding Google Analytics through nuget package version as mentioned below:
EPiServer.GoogleAnalytics      1.6.0.7518
EPiServer.GoogleAnalytics 1.7.0.8000 (only valid for version 8 and above)
EPiServer.GoogleAnalytics 1.7.1.8000 (only valid for version 8 and above)
But still it did not work. I have seen a modeule and modulebin folder under root & modules folder under VPP. Can you confirm do I need to delete both or any of them?
By adding through nuget the 1.6 version, I can see a config file under module->protected. Is this correct?
Cheers,
Naz
#121335
May 06, 2015 19:30
You're still in base 7.5 (7.5.394.2) correct? Or have you updated to a more recent version of CMS 7.5? If you're still on base 7.5, then you're expected to see GA add-on folder under vpp/modules folder.  I think you may see some GA dlls in modulesbin folder as well.
#121380
May 07, 2015 18:59
Thanks for your reply. I have updated it to the 7.19 version and I have updated package from nuget too, but it is still the same. I can see dlls in my modulesbin folder? Do I need to remove them manually?
Cheers,
Naz
#121382
May 08, 2015 9:51
Yes, please try removing the assemblies in modulesbin.
#121410
May 08, 2015 20:04
