Hello Binh
Are you definitely making the request over SSL and you've done all the necessary work to create a self signed cert and install it on your machine etc?
David
Hi David,
I have done all necessary configuration but still cannot detect service api. I installed EPiServer site as following steps:
- Install EPiServer 7.5 empty site from EPiServer center
- Install EPiServer Ecommerce on this site from EPiServer center
- Add MVC sample code for this commerce site
- Upgrade to latest version for EPiServer Ecommerce from nuget
- Then install ecommerce service api from nuget
- Configure SSL for this site
I tried to install a EPiServer site from Visual Studio as creating empty EPiServer sample project with EPiServer extension then install service api package. It's OK.
Do you know why it failed when I tried to install from EPiServer center first?
Thanks a lot,
Hi guys,
I have the same issue. Did you find out what the problem is?
Regards,
Christer
Hi again,
I managed to get it to work by reinstalling the ServiceApi.
I haven't tried the workaround for the EPiServer.ServiceApi (without Commerce), but it's worth a try.
Regards,
Christer
Hi guys,
I am working with EPiServer CMS 8. I want to set up EPiServer service api to allow external system being able to connect to.
I set up service api as following as http://world.episerver.com/documentation/items/episerver-service-api/configuration-and-overview/setting-up-episerverserviceapi.
Then I tried to call service api to get authentication token but response message with error code is 404 - not found.
I don't think I need to add more route config for this api, right?
Do I need to set up more any configuration else? Can any guys help me please?
Thanks a lot,
