You can create a custom attribute and replace the built in EditorDescriptor for the CategoryList type. Here's a sample:
Custom attribute:
[AttributeUsage(AttributeTargets.Property | AttributeTargets.Field, AllowMultiple = false)]
public class CategorySelectionAttribute : Attribute
public bool Multiple { get; set; }
public int RootCategoryId { get; set; }
public string RootCategoryName { get; set; }
public CategorySelectionAttribute()
Multiple = true;
public int GetRootCategoryId()
if (RootCategoryId > 0)
return RootCategoryId;
if (!string.IsNullOrEmpty(RootCategoryName))
var category = Category.Find(RootCategoryName);
if (category != null)
return category.ID;
return Category.GetRoot().ID;
Editor descriptor:
[EditorDescriptorRegistration(TargetType = typeof(CategoryList), EditorDescriptorBehavior = EditorDescriptorBehavior.OverrideDefault)]
public class CustomCategoryListEditorDescriptor : EPiServer.Cms.Shell.UI.ObjectEditing.EditorDescriptors.CategoryListEditorDescriptor
var categorySelectionAttribute = attributes.OfType<CategorySelectionAttribute>().FirstOrDefault();
if (categorySelectionAttribute != null)
metadata.EditorConfiguration["multiple"] = categorySelectionAttribute.Multiple;
metadata.EditorConfiguration["root"] = categorySelectionAttribute.GetRootCategoryId();
Then you can decorate your content type property like this:
[CategorySelection(RootCategoryId = 123)]
public virtual CategoryList MyCategories { get; set; }
Or like this:
[CategorySelection(RootCategoryName = "MyCategoryName")]
Upgrade from cms 6r2 to 7.9.2
Im actually looking for a category picker that gets child categories from a specific Category node?
Needs to be a multi select. Listing for example News Categories or Image Categories and so on...
Its helping the editors since we do have a lot of Categories.
When Im using a legacy Category Picker. It does not work when a new page is created.
Throws a [JsonSerializationException: Unexpected initial token 'Null' when populating object. Expected JSON object or array. Path '', line 1, position 4.]
[BackingType(typeof(CategoryPicker))]
[UIHint(EPiServer.Web.UIHint.Legacy)]
