How to Create Custom Login Control Episerver Cms
how to Custom Login Control In episerver Cms I Can't use Util/login.aspx loginUrl address I want to Create Login Contol In HeaderMenu  Of the Home Page
#121137
May 04, 2015 10:42
tell me guys urgent i need
#121162
May 04, 2015 13:49
you will need custom login page (or controller + view if in MVC case). Add link to that page in header: create new page type, set page template to newly created view, then you can add new property to start page - ContentReference, that will point to login page. Later you will need to fill in that reference in CMS. then you will need login logic. probably username and password will be post payload - you can use then in your authentication process - MemembershipProvider.ValidateUser(). After then you may use FormsAuthentication.Signin() - to let user in your site.
#121211
May 04, 2015 21:15
i can't use util/login.aspx page i was create custom login page so i want to it will be work as well as util/ login.aspx   editmode,admode will be display
#121266
May 06, 2015 7:01
#121267
May 06, 2015 7:01
set it as loginUrl in <authentication> element in web.config then
#121268
May 06, 2015 7:48
i want to create in  alloy tech demo  website customer login page i didn't understand it so please explain how it is created (methods and properties)
#121269
May 06, 2015 7:55
This is a example for regular MVC4 with a custom database for userinfo.
You can use it to see how it can be done in Alloy, even though you might need to tweek it a little to work in a EPiServer project
http://www.codeproject.com/Articles/482546/Creating-a-custom-user-login-form-with-NET-Csharp
#121272
May 06, 2015 8:58
ya but i want create it in webform alloy tech 6.o
#121274
May 06, 2015 9:17
Here is a example with webform:
http://www.asp.net/web-forms/overview/security/create-a-secure-aspnet-web-forms-app-with-user-registration,-email-confirmation-and-password-reset
You can find more info here:
http://lmgtfy.com/?q=csharp+webform+custom+login
#121276
May 06, 2015 9:24
