Collection of Static Blocks
Minesh Shah (Netcel)
OMVPOpal Administrator CertificationSaaS CMS Administrator CertificationOpal Tools CertificationODP Developer CertificationExperimentation Strategist CertificationPaaS CMS Administrator Certificationworkspace_premiumODP Administrator CertificationPaaS CMS Developer CertificationSaaS CMS Developer Certification
Im trying to mimic functionality similar to the ElencySolutions.MultipleProperty basically i would like to build up a collection of static blocks and was wondering best way to approach this.
I dont want to use a content area as these blocks are static and not available in Edit mode.
#121252
May 05, 2015 17:24
One way of doing this without developing any custom properties is to nest your local blocks in another local block. It could look something like this:
public abstract class BlockCollection : BlockData
    public abstract IEnumerable<BlockData> GetBlocks();
[ContentType(DisplayName = "My block collection", Description = "", GUID = "EEEB790D-3C10-4EAB-BAB7-ACBE14780DBC", AvailableInEditMode = false)]
public class MyBlockCollection : BlockCollection
    public virtual MyFirstBlockType FirstBlock { get; set; }
    public virtual MySecondBlockType SecondBlock { get; set; }
    public override IEnumerable<BlockData> GetBlocks()
        return new BlockData[] { FirstBlock, SecondBlock };
Then you can have a block view looking like this in ~/Views/Shared/Blocks/BlockCollection.cshtml:
@model BlockCollection
@foreach (var block in Model.GetBlocks())
    @Html.PropertyFor(m => block)
You can actually use the same view for all your block collections inheriting from BlockCollection by registering a template model:
[ServiceConfiguration(typeof(IViewTemplateModelRegistrator))]
public class TemplateCoordinator : IViewTemplateModelRegistrator
    public const string BlockFolder = "~/Views/Shared/Blocks/";
    public void Register(TemplateModelCollection viewTemplateModelRegistrator)
        // BlockCollection partial
        viewTemplateModelRegistrator.Add(typeof(BlockCollection), new TemplateModel
            Name = "BlockCollectionView",
            Inherit = true,
            AvailableWithoutTag = true,
            Path = BlockPath("BlockCollection.cshtml")
    private static string BlockPath(string fileName)
        return string.Format("{0}{1}", BlockFolder, fileName);
#121303
Edited, May 06, 2015 14:14
Thank you, i will give this a go although for now have used the MultipleProperty
#121391
May 08, 2015 11:44
