Does your client resource register work on clean Alloy templates site?
Page template must render required client resources for "Header" and "Footer" areas. Check it out: Requirements for Page Templates.
You can also download Sample module source code, it contains client resource register and provider examples. It was created for EPiServer 7, but client resource management part should be accurate.
Client resource register example in Disqus for EPiServer.
I'm trying to get Client Resources up and running and I think there is some part I'm missing.
I'm trying to get a [ClientResourceRegister] class to run on every EPi page for the visitor. depending on pagedata / page types I'm going to load different resources.
But the class itself is never touched, even though the pages are inherited from EPiServer.Web.Mvc.PageController and the Register class inherits from PageClientResourceRegister.
All I've found is Disqus plugin but that didn't help me much. Is there some references needed to get EPi to run the Register class? Does anyone have a working example around?
Cheers /W
