Upgraded to CMS 8.0
Minesh Shah (Netcel)
OMVPOpal Administrator CertificationSaaS CMS Administrator CertificationOpal Tools CertificationODP Developer CertificationExperimentation Strategist CertificationPaaS CMS Administrator Certificationworkspace_premiumODP Administrator CertificationPaaS CMS Developer CertificationSaaS CMS Developer Certification
After the upgrade i ran updated the database using the console manager script although when trying to run website i get the following error message
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\8736a6fe\ed65b93\App_global.asax.0.cs    Line: 0
Stack Trace:
   EPiServer.Common.Configuration.ConfigurationSectionBase`1.GetInstance(String sectionName) +257
   EPiServer.Common.Configuration.EPiServerCommonSection.get_Instance() +39
   EPiServer.Common.ImplementationModule.LoadCoreConfiguration() +43
   EPiServer.Common.Settings.LoadSettings() +196
   EPiServer.Common.InitializationModule.Initialize(InitializationEngine context) +48
   EPiServer.Framework.Initialization.<>c__DisplayClass5.b__4() +56
   EPiServer.Framework.Initialization.ModuleNode.Execute(Action a, String key) +73
   EPiServer.Framework.Initialization.ModuleNode.Initialize(InitializationEngine context) +141
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +253
[InitializationException: Initialize action failed for Initialize on class EPiServer.Common.InitializationModule, EPiServer.Common.Framework.Impl, Version=7.5.446.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7]
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +641
   EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType) +247
   EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType) +574
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +78
   EPiServer.Global..ctor() +83
   Bdp.com._2014.EPiServerApplication..ctor() +42
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\8736a6fe\ed65b93\App_global.asax.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +113
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +232
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +83
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1136
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +128
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +18
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +60
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +260
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9950728
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +101
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +254
#119979
Apr 08, 2015 13:13
Is your website using CommonFramework in any mean? If not, it should be safe to remove dependencies on that.
Regards.
/Q
#119983
Apr 08, 2015 14:15
Thank you, not quite sure how it got their.
What is the issue with this Framwork and EPi 8.3?
#119989
Apr 08, 2015 15:39
Just seen this article which explains : http://world.episerver.com/documentation/Items/Upgrading/EPiserver-Commerce/8/Breaking-changes-Commerce-8/Removing-dependency-on-Common-Framework/
#119990
Apr 08, 2015 15:40
hi Minesh,
I am handle the same problem. And i am using episerver mail so episerver mail depends on the common framework.
Any sollution??
#149366
May 30, 2016 17:20
