To create a folder, you can use ContentFolder instead of ImageFile
Regards.
/Q
To create a folder you should use ContentFolder as the type argument to GetDefault<T> as
contentRepository.GetDefault<ContentFolder>(parentLink)
Thanks both, that works perfectly!
To anyone in the same boat I've thrown some rough code which will create a folder in the root if a parent content reference isn't passed and in a sub folder if it is.
//Create a Folder in the root
public ContentReference CreateFolder(string folderName)
var contentRepository = ServiceLocator.Current.GetInstance<IContentRepository>();
var contentFile = contentRepository.GetDefault<ContentFolder>(SiteDefinition.Current.GlobalAssetsRoot);
contentFile.Name = folderName;
return contentRepository.Save(contentFile, SaveAction.Publish, AccessLevel.NoAccess);
//Create a new folder
public ContentReference CreateFolder(string folderName, ContentReference parentReference)
var contentFile = contentRepository.GetDefault<ContentFolder>(parentReference);
- Jon
Hi - I'm in the process of migrating an image importer from Epi 6R2 to Epi 7.5 and while I can successfully import images, I'm unable to programatically create new folders to put the images in.
I'd like to create a folder stucture similar to the following:
The code I use to save the images is as follows:
Jon
