Seems to be that i activated ClassicLinkRouting to get my ContentProviders to work.
protected override void RegisterRoutes(RouteCollection routes)
base.RegisterRoutes(routes);
routes.Insert(0, ServiceLocator.Current.GetInstance<ClassicLinkRoute>());
And it didn't like it...
Any idea how to run ClassicLinkRouting parallell in epi 7.19? I do run webForms and not MVC.
I've got the exact same problem. Did you find a solution to this?
/Peter
Hi Peter,
It was a chain of configuration errors.
But the root problem was routing errors
http://world.episerver.com/forum/developer-forum/-EPiServer-75-CMS/Thread-Container/2015/4/trailing-slash-on-mediafiles/
Also make sure you have cms, shell, Episerver.Packaging, Episerver.Packaging.UI folders in modules/_protected folder. <-- this can vary depending on configuration and Epi version, i don't really know here.
Also i did Register ClassicLinkRoute with an override class at row 20(!) in the routetable:
routes.Insert(20, ServiceLocator.Current.GetInstance<MyOwn.ClassicLinkRouteForContentProviders>());
Regards
v7.19.2: Now for sudden Episerver UI do not render the right adress in top menu to Dashboard, CMS Edit, Catalog UI or Visitor Groups
http://mydomain.com/?action=Index&controller=Home&moduleArea=Cms
http://mydomain.com/?action=Index&controller=Dashboard&moduleArea=Shell
http://mydomain.com/?action=Index&controller=Catalog&moduleArea=EPiServer.Commerce.Shell
To Admin works: http://mydomain.com/episerver/CMS/Admin/Default.aspx
Where to start looking? it has worked but stoped for sudden.
