Issue logging in (Redirect fails)
So I am trying to setup EPiServer 8 in a new project.
When i try to access mysite.local/episerver/cms the redirect fails
mysite.local/auth/login?ReturnUrl=%2Fepiserver%2Fcms
No parameterless constructor defined for this object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.MissingMethodException: No parameterless constructor defined for this object.
Source Error:
Stack Trace:
[MissingMethodException: No parameterless constructor defined for this object.]
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +159
   System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +256
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +127
   System.Activator.CreateInstance(Type type) +78
   System.Web.Mvc.DefaultControllerActivator.Create(RequestContext requestContext, Type controllerType) +92
[InvalidOperationException: An error occurred when trying to create a controller of type 'Unipension.SelfService.Web.Pages.Auth.AuthController'. Make sure that the controller has a parameterless public constructor.]
   System.Web.Mvc.DefaultControllerActivator.Create(RequestContext requestContext, Type controllerType) +256
   System.Web.Mvc.DefaultControllerFactory.CreateController(RequestContext requestContext, String controllerName) +169
   System.Web.Mvc.MvcHandler.ProcessRequestInit(HttpContextBase httpContext, IController& controller, IControllerFactory& factory) +270
   System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state) +147
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +12288259
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +288
I can access mysite.local/util/login.aspx - but the login fails, with nothing written to the log :/
Can someone here help me shine some light on this? I am utterly lost :)
#118992
Mar 18, 2015 14:35
It looks like more than a MVC error :
Try to add parameterless constructor to AuthController to see if it works for you.
Regards.
/Q
#119000
Edited, Mar 18, 2015 16:41
I think you are right, I will give it a go :)
#119022
Mar 19, 2015 9:53
