Errors compiling after Episerver 8 update
I just updated from Episerver 7.5 to 8 using NuGet package manager in Visual Studio 2012.
Properties for my visual studio project  is set to .NET Framework 4.5
When I'm compiling my test site I get following errors. Do I have to change anything manually in the References folder?
Error1Warning as Error: 'EPiServer.Core.CategoryList.GetCategoryName(int)' is obsolete: 'Use CategoryRepository.Get() to load individual categories by id and retrieve their name.'C:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\Core\CategorizableExtensions.cs3178Alloy
Error2The best overloaded method match for 'EPiServer.DataFactory.GetPage(EPiServer.Core.PageReference, EPiServer.Core.LoaderOptions)' has some invalid argumentsC:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\Core\ContentReferenceExtensions.cs5720Alloy
Error3Argument 2: cannot convert from 'EPiServer.Core.ILanguageSelector' to 'EPiServer.Core.LoaderOptions'C:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\Core\ContentReferenceExtensions.cs5759Alloy
Error4Warning as Error: 'EPiServer.Core.LanguageSelectorContext' is obsolete: 'Simplify code in content providers to only use the Language property to get requested language (ILanguageSelector.Language). Removed usage of LanguageSelectorContext since fallback languages are now handled outside the provider.'C:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\ContentProviders\ClonedContentProvider.cs16231Alloy
Error5Warning as Error: 'EPiServer.Core.ILanguageSelectorExtensions.SelectPageLanguage(EPiServer.Core.ILanguageSelector, EPiServer.Core.LanguageSelectorContext)' is obsolete: 'Simplify code in content providers to only use the Language property to get requested language (ILanguageSelector.Language). Removed usage of LanguageSelectorContext since fallback languages are now handled outside the provider.'C:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\ContentProviders\ClonedContentProvider.cs16617Alloy
Error6Warning as Error: 'EPiServer.Core.ILanguageSelectorExtensions.SetInitializedLanguageBranch(EPiServer.Core.ILanguageSelector, EPiServer.Core.LanguageSelectorContext)' is obsolete: 'Simplify code in content providers to only use the Language property to get requested language (ILanguageSelector.Language). Removed usage of LanguageSelectorContext since fallback languages are now handled outside the provider.'C:\EPiServer\ExampleEPiServerSite3\wwwroot\Business\ContentProviders\ClonedContentProvider.cs17813Alloy
#119202
Mar 24, 2015 10:16
Hi Dan,
you've hit some breaking changes. You don't need to change references, but you do need to change your code.
1. As the erorr says you need to modify the way you get categories.
2. Hard to say without seeing the code, but first of all you might want to use ServiceLocator.Current.GetInstance<IContentLoader>().Get<Contenttype>(...) instead of DataFactory.
3-6. LanguageSelector is now replaced with CultureInfo, so that needs to be changed where you use it.
#119203
Mar 24, 2015 10:59
Thanks for the reply!
I'm using the Alloy test-site I got when installing Episerver 7.5
Do I have to modify the Alloy site or is there any way I can get a new Alloy site for Episerver 8?
/Dan
#119204
Mar 24, 2015 11:23
If you use the latest version of the EPiServer CMS Visual Studio extension to create a new site with the Alloy templates they will be 8.0+ compatible.
#119205
Mar 24, 2015 11:42
