No progress unfortunately. I'd say custom visitor groups would be the way to go.
AFAIK there is no way to switch from session-based to just cookie. A few of the built-in visitor group criteria DO set a cookie (e.g. the "Number of Visits" criteria leaves the cookie "EPi:NumberOfVisits") but the collective persistance data per user is session only.
You probably have to develop a custom criteria that leaves a cookie containing the info you want. In addition, you'd need to develop your own storage for the actual persisted data. David Knipe and I had a discussion regarding this in the comments section over at http://www.david-tec.com/2015/09/cookie-drop-block-for-episerver/
I've been looking for a while now trying to find out if there is a configuration change that will change visitor groups over from session based retention to cookie based.
I'm aware this can be done through custom visitor groups but i'm looking for a simpler solution.
Cheers Ben
