Clean EPi 8 with Sql 2008
trying to install episerver using the latest extenstion which install a mdf file in the app_data
when trying to attach it to our sql 2008 i get an errro 706 that the db is in another version.
is there an easy way to move an empty EPi Db to sql 2008( which should support episerver accroding to the specs) ?
#119425
Mar 27, 2015 11:24
Seems like the extension creates a 2012 version of the dbf file, you can not attach that to 2008.
I would download the deployment center and create the clean database with that directly against your 2008 database server.
#119426
Mar 27, 2015 11:44
You might run this sql query before attaching to SQL Server 2008:
ALTER DATABASE VJ_DATABASE
SET COMPATIBILITY_LEVEL = 100;
GO
Or this:
http://stackoverflow.com/questions/26346647/the-database-cannot-be-opened-because-it-is-version-782-this-server-supports-ve
Regards.
/Q
#119430
Mar 27, 2015 12:01
I stumbled on then when opening an existing project in Visual Studio 2015 with a local database in App_Data.
The solution was to change the connection string, from;
Data Source=(LocalDb)\v11.0
to
Data Source=(LocalDB)\MSSQLLocalDB
Hope this helps someone
Fredrik
#123433
Jul 03, 2015 14:24
Pär Wissmark
You need to downgrade the database.
If you dont have any sql management studio for the newer version, install an express version to do the down grade in
Right click on database
-task
-generate script
-choose entire database
next setp
-advanced button
-script for specific version(choose wich version u want)
-type of data to script(schema and data)
-choose location
next step
When you have the script run them in the sql 2008
Its important that you change the location of the databasefiles in the script before runninge them
#123447
Jul 04, 2015 17:45
