I suggest that you create an init module on the client since this will make the code run at the right time. Here is a copy paste example from something I worked on recently:
Module.config:
<clientModule initializer="[your module class including namespace]">
<moduleDependencies>
<add dependency="CMS" type="Require RunAfter" />
</moduleDependencies>
</clientModule>
Client module sample:
define([
// Pull in the patches. Not used here, just evaluated, since this is the first module loaded when starting the application.
"dojo/_base/declare",
"dojo/_base/lang",
"epi/_Module",
"epi/dependency",
"instantTemplates/AddItemFromTemplateCommandProvider"
function (
declare,
lang,
_Module,
dependency,
return declare([_Module], {
// summary:
// Template module implementation.
// tags:
// internal
_settings: null,
constructor: function (settings) {
this._settings = settings;
initialize: function () {
var commandregistry = dependency.resolve("epi.globalcommandregistry");
//We need to wait for the viewsettings to initialized before creating the global toolbar command provider
commandregistry.registerProvider("epi.cms.globalToolbar", new AddItemFromTemplateCommandProvider({templatesRoot : this._settings.templatesRoot}));
Linus,
That did it for me (specifically the module.config settings) - thanks!.
I have the following javascript in the file ClientResources/Scripts/widgets/media/Mediacommands.js:
My module.config looks like this:
This is intended to add a button to the Editor toolbar, and *sometimes* works. However around 70% of the time I see the error Can't resolve dependency "epi.globalcommandregistry" in the console.
This corresponds to the line registry = dependency.resolve('epi.globalcommandregistry'), in the javascript above.
Is there any reason why the dependency can't be resolved at some times and more to the point, how can I ensure it's resolved every time?
Mark
