I'm not an expert about data import, but the message suggests that the property is defined by code, with one or more attributes differ from property in the data package. The strongly typed property has "higher" property and will not be overwritten by importing process.
It also looks like we have one typo in the message :)
Regards.
/Q
Hi Quan,
Thanks for the help!
All properties are defined in the code, and populated "by hand" in edit mode. I'm not using 'override void SetDefaultValue', nor creating pages from the code.
Are these warnings bug or feature then? :)
Hi Dejan,
Did you ever find the solution to this problem? We are experiencing the same thing.
Hi everyone,
I'm trying to export some pages from staging to test server.
Test run for export didn't report any errors.
Test run for import reported a lot of warnings: "Local property X originates from code and hence it is not overwritten by imported property".
I didn't get any additional information like which page id, page type id, etc.
Do you know what can be the reason for these warnings?
Thanks!
