TinyMCE editor and Blocks
A general question really - the tinyMCE editor allows the drag and dropping of any block within the EpiServer UI, but sometimes I run into issues with certain blocks being rendered.  My question is "Is the EpiServer TinyMCE built for this purpose as it initially has no "insert block" button/function or should all blocks sit outside by default and custom buttons created for the insertion of blocks?
Steve
#117313
Feb 17, 2015 17:38
Hi Steve,
Yes, the TinyMCE editor supports rendering of blocks. It will call the partial renderer of the block to render it. What type of issues are you running in to?
/T
#117314
Feb 17, 2015 18:06
Hi Toni,
Thanks for the swift response :)
That's great to hear. I was initially having issues with the internal links not resolving correctly (as described here: http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=116262&epslanguage=en), so I put in a workaround to fix that, but subsequently seems to have broken the block rendering.
Steve
#117317
Feb 17, 2015 18:16
What was the workaround? I looked at the other link and you are using something I haven't seen before to render the property:
<Web:BoundProperty ID="MainContentBoundProperty" runat="server" />
Why not use the default EPiServer:Property user control to render your properties?
/T
#117318
Feb 17, 2015 18:21
Happens with either property control, the workaround i used was
/// <summary>
/// To the HTML string fixed.
/// </summary>
/// <param name="instance">The instance.</param>
/// <returns></returns>
public static string ToHtmlStringFixed(this XhtmlString instance)
if (null == instance)
return null;
if (instance.IsEmpty)
return String.Empty;
StringBuilder stringBuilder = new StringBuilder();
foreach (IStringFragment stringFragment in instance.Fragments)
UrlFragment urlFragment = stringFragment as UrlFragment;
if (null != urlFragment)
Uri externalUrl;
if (TryGetExternalUrl(urlFragment.InternalFormat, out externalUrl))
stringBuilder.Append(externalUrl);
continue;
stringBuilder.Append(stringFragment.GetViewFormat());
return stringBuilder.ToString();
/// <summary>
/// Tries the get external URL.
/// </summary>
/// <param name="internalFormat">The internal format.</param>
/// <param name="externalUrl">The external URL.</param>
private static bool TryGetExternalUrl(string internalFormat, out Uri externalUrl)
try
//The call to GetExternal URL here is a wrapper around a call to EPiServer.Global.UrlRewriteProvider.ConvertToExternal.
var builder = new UrlBuilder(internalFormat);
Global.UrlRewriteProvider.ConvertToExternal(builder, null, Encoding.ASCII);
externalUrl = builder.Uri;
catch (Exception)
externalUrl = null;
return null != externalUrl;
#117319
Feb 17, 2015 18:34
