RequestContext.GetContentLink returns null
Hi all,
I'm trying to implement a localizable errorpage using the tutorial of Karoline Klever, and this seems to be working okay-ish. For some reason, however, I am getting back null when I try to use the function public static ContentReference GetContentLink(this RequestContext reqContext) from EPiServer.Web.Routing.RequestContextExtension. This means the whole site still fails to render.
As said in the linked tutorial, I did set
ControllerContext.RouteData.DataTokens[RoutingConstants.NodeKey] = errorPage.ContentLink;
But that doesn't seem to be enough for EPiServer 7.5 (we're using EPiServer 7.6.3). What else do I need to do to make this work properly?
Regards,
PatrickBregman
#117138
Feb 12, 2015 10:14
Hi Patrick,
You have probably solved your problem by now, if you havent, try adding this:
ControllerContext.RequestContext.RouteData.DataTokens[RoutingConstants.NodeKey] = errorPage.ContentLink;
Regards,
Robert
#118286
Mar 03, 2015 21:13
I totally forgot to post that solution! But yeah, that solved it.
Patrick
#118299
Mar 04, 2015 7:50
