EPiServer Find Auto Suggest
I have a question reagrding search suggestions.
Is it possible to implement auto suggest using EPiServer Find?
I checked the Find SDK and there is an example for auto complete which is totally understandable.
I just want to know if it is possible to suggest variants without doing a search.
Thank you.
#117284
Feb 16, 2015 21:41
Hello Islam
Using Find to provide autocomplete search results is certainly possible. The code below can be used to provide a suggested list of results for Name property of the Foo type:
public JsonResult Prefix(string term)
    var results = client.Search<Foo>()
        .Filter(x => x.Name.PrefixCaseInsensitive(term))
        .Select(x => x.Name)
        .StaticallyCacheFor(TimeSpan.FromHours(1))
        .GetResult();
    return Json(results.Select(x => x), JsonRequestBehavior.AllowGet);
Simply add the code above to a controller to use in your client side javascript.
David
#117286
Feb 17, 2015 0:28
