Hi Jesper,
Your language file looks fine.
I have similar problem. Localized text is cached on server side and in browser.
It works when I kill the IIS from task manager, run the website, clear browser cache, and refresh the page :)
Can you also try to remove <menuitems> section from your language file and see what happens?
After adding <menuitems> section in my language files, edit mode breaks: blank screen, no page tree, etc.
I just tried to remove the <menuitems> element and I am afraid it did not help.
Thank you for your suggestion though!
Alright, problem solved.
Language-files checked out to be ok.
It was a silly mistake with a missing user-language not being set (Episerver --> "My settings" --> "Display options" --> "Personal language")
For some reason EPiServer does not pickup our localized texts for property labels, but instead use the english texts. I have checked the following:
- ContentLanguage.PreferredCulture is 'da'
- CultureInfo.CurrentUICulture is 'da'
When retrieving language-texts for content from the language-file, the 'da' texts are correctly retrieved, so it only seems to be a problem when retrieving texts for localized properties for EPiServer.
This is my language file:
This is my housedetailspage.cs:
BaseViewPage is a class that inherits directly from PageData.
Any input is appreciated :)
Best regards
Jesper
