Cannot get Url.ContentUrl with my custom Html Helper
I'm working with EPiServer since september now and I'm using more advanced features now but I'm stuck with something and I'd really love if someone can help me.
I have made a custom HTML Helper to use with Razor MVC to be able to use display options without having to create a custom ContentAreaRendered and everything that seems to go with it but any links I use in my view are internal ugly url (aspx stuff) and if I have any method that are supposed to transform this ugly URL into a friendly URL it does not work.
Here is part of my block model:
        [CultureSpecific]
        [Display(
            Name = "Link",
            Description = "Link for the button",
            Order = 30)]
        [BackingType(typeof(PropertyUrl))]
        public virtual Url URL { get; set; }
        [CultureSpecific]
        [Display(
            Name = "Image (Optional)",
            Description = "An optional image to display under the description",
            Order = 40)]
        [UIHint(UIHint.Image)]
        public virtual ContentReference Image { get; set; }
Here is my Helper:
public static XhtmlString RowFromArea(this HtmlHelper html, Expression> expression)
    var returnString = "";
    var area = ModelMetadata.FromLambdaExpression(expression, html.ViewData).Model as ContentArea;
    if (area != null)
        returnString += "
"; foreach (ContentAreaItem item in area.FilteredItems) { var block = item.GetContent(); // LoadDisplayOption(item); returnString += "
" + html.PropertyFor(x => block) + "
"; } returnString += "
"; //var urlResolver = ServiceLocator.Current.GetInstance(); //urlResolver.GetVirtualPath(new ContentReference()); } return new XhtmlString(returnString); }
Here is the page view where I call the actual helper:
    Layout = "~/Views/Shared/Layouts/_Layout.cshtml";
@Html.RowFromArea(x => x.BottomArea)
@Html.RowFromArea(x => x.RightArea)
And this is what I have in my block partial view:
You see I have an image that is a ContentReference and a Link that is can be either to an internal page or an external URL. And I get only ugly URL. I'm using the same
@Url.ContentUrl(Model.URL) in another view that is not passing through my helper and it's working properly so I think the problem is coming from something I missed in my helper.
Thank you.
#118132
Feb 27, 2015 14:52
Just a small message to say I'm still looking for a solution for this.
Thanks.
#118741
Mar 12, 2015 16:54
For info, I just fixed my bug. My helper was returning a XhtmlString and apparently for the UrlHelper to properly do its jobs you need to return a MvcHtmlString.
Took me two months but it's fixed :D
#121631
May 15, 2015 20:52
