So after a lot of trial and error I've managed to get this working with the following.
[TinyMCEPluginButton(PlugInName = "template",
ButtonName = "template",
GroupName = "misc",
IconClass = "mceIcon mce_template",
EditorInitConfigurationOptions = "{ template_templates: [{ title : 'test', description : 'test', src : '../../util/editor/tinymce/plugins/template/templates/test.htm' }] }")]
public class Template
Not sure how correct this is, but it's working atm.
Cheers
Mark
Hey Guys,
Has anyone been able to add the TinyMCE template plugin (https://www.tinymce.com/docs/plugins/template/) to EPiServer CMS 7.5 and define htm templates?
I've followed the instructions at http://world.episerver.com/documentation/Items/Developers-Guide/EPiServer-CMS/75/Editing/Customizing-the-TinyMCE-editor/ successfully, however when I click the template button there are no templates in the drop down list to select from. I'm just not sure how to define the path to the .htm templates... any ideas? I'm just trying to set the path to the same location as the plugin folder, i.e. /util/Editor/tinymce/plugins/template
I've tried a few different things in the Template.cs file as you can see below.
Cheers
Mark
