Try with a different user or reset your views (beneth my settings -> display options)
No problem. I actually got this problem when demoing content providers to over a hundred developers. I took a gamble on "reset views", and lucky for me, it worked. *phew*
I have a problem with using additional mediaproviders. I found already an article on how to add an extra tab on the Media-assets panel, which i can use to access extra folders outside the normal Media folders.
I add the plugin to the 'Assets' area, however after adding it, and changing the value of the area, it refuses to move to another location, no matter what predefined area i use.
I want to use 'PluginArea.AssetsDefaultGroup' but it refuses to move to that location.
What do i need to do to change my the location of my plugin? I got the feeling that the definition of the plugin is also stored in the database and is not properly synched with the definition in code. Am i correct or am i missing something in code?
