Can you open the URLs that give you 500 from console in a new tab? That should give you a more detailed error message.
I am getting the following error message:
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] EPiServer.Cms.Shell.UI.ObjectEditing.InternalMetadata.LinkModel.ModifyIContentProperties(LinkItem serverModel, LinkModel clientModel) +274 EPiServer.Cms.Shell.UI.ObjectEditing.InternalMetadata.LinkModel.ToClientModel(Object serverModel) +353 EPiServer.Cms.Shell.Json.LinkItemCollectionConverter.WriteJson(JsonWriter writer, Object value, JsonSerializer serializer) +202 Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeConvertable(JsonWriter writer, JsonConverter converter, Object value, JsonContract contract, JsonContainerContract collectionContract, JsonProperty containerProperty) +506 Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeList(JsonWriter writer, IEnumerable values, JsonArrayContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty) +911 Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeDictionary(JsonWriter writer, IDictionary values, JsonDictionaryContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty) +1436 Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.SerializeObject(JsonWriter writer, Object value, JsonObjectContract contract, JsonProperty member, JsonContainerContract collectionContract, JsonProperty containerProperty) +1335 Newtonsoft.Json.Serialization.JsonSerializerInternalWriter.Serialize(JsonWriter jsonWriter, Object value, Type objectType) +178 Newtonsoft.Json.JsonSerializer.SerializeInternal(JsonWriter jsonWriter, Object value, Type objectType) +936 EPiServer.Shell.Services.Rest.RestResult.ExecuteResult(ControllerContext context) +31 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +109 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +890 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +890 System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +97 System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +241 EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult) +175 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +606 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +288 |
Could you send a content model class where the property is defined?
I have used dojo custom properties for key value items and LinkItemCollection in two different Block type.
Unable to publish Links(LinkItemCollection Property) and it throws "NetworkError: 500 Internal Server Error - http://xxx/EPiServer/cms/Stores/contentdata/33_99?dojo.preventCache=1447940258166"
Could you please help me to resolve the issue?
Episerver Version: 8.1.0.75
