Not able to create new node under the root folder in Episerver CMS5
HI,
I need to create new test side in Episerver CMS 5. But in Edit mode I am not able to create/Past any node under the root page of Episerver CMS5.
When i right click on Root folder in edit mode, it is showing create page options is disable
Can you please help me.
BEst Regards,
Deepali
#140864
Nov 02, 2015 14:11
Hi, Deepali,
Might be too late for the answer, but either you do not have any available page types under a root page or you do not have sufficient permissions to create pages.
If you have access to admin mode, you should be able to set this under "set access rights" and you should be able to view available page types for root page as well. Check out page 16 and 40.
http://world.episerver.com/globalassets/documents/manuals/episerver-cms/5-r2/administrators-manual-episerver-cms-5-r2-english-revb.pdf
Are you starting a new project on CMS 5? If so, why? :)
BR,
Marija
#141992
Nov 25, 2015 16:52
