Error when trying to pick XForm
I get this error when I hit the ... button that should show a list of XForms. The site is upgraded from EPiServer 6 to 8.11
It only occurs on one of the sites (the one in pruduction sadly)
Has anyone seen this and if so,is there a cure?
An object or column name is missing or empty. For SELECT INTO statements, verify each column has a name. For other statements, look for empty alias names. Aliases defined as "" or [] are not allowed. Change the alias to a valid name.
 Exception Details: System.Data.SqlClient.SqlException: An object or column name is missing or empty. For SELECT INTO statements, verify each column has a name. For other statements, look for empty alias names. Aliases defined as "" or [] are not allowed. Change the alias to a valid name.
Source Error:
Stack Trace:
[SqlException (0x80131904): An object or column name is missing or empty. For SELECT INTO statements, verify each column has a name. For other statements, look for empty alias names. Aliases defined as "" or [] are not allowed. Change the alias to a valid name.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +3242916
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +345
   System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4927
   System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +92
   System.Data.SqlClient.SqlDataReader.get_MetaData() +102
   System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +552
   System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +3140
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite) +554
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +98
   System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +307
   EPiServer.Data.Dynamic.Providers.DbDataStoreProvider.ExecuteReader(Query query, IDbCommand command, ProviderCallContext providerCallContext) +138
   EPiServer.Data.Dynamic.Providers.<>c__DisplayClass30`1.b__2f() +565
   EPiServer.Data.Providers.<>c__DisplayClass2f`1.b__2e() +56
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +882
   EPiServer.Data.Dynamic.Linq.Query`1.Execute() +317
   EPiServer.Data.Dynamic.Linq.Query`1.System.Collections.IEnumerable.GetEnumerator() +14
   EPiServer.XForms.XForm.GetXformsList(IEnumerable formsPropsList) +108
   EPiServer.UI.Edit.XFormSelect.GetPages(String formFolder, Boolean myFormsOnly, String formId, String sortExpression, Int32 maximumRows, Int32 startRowIndex, Int32& rowCount) +1553
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +128
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +146
   System.Web.UI.WebControls.ObjectDataSourceView.InvokeMethod(ObjectDataSourceMethod method, Boolean disposeInstance, Object& instance) +951
   System.Web.UI.WebControls.ObjectDataSourceView.ExecuteSelect(DataSourceSelectArguments arguments) +1916
   System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +26
   System.Web.UI.WebControls.BaseDataBoundControl.EnsureDataBound() +139
   System.Web.UI.WebControls.GridView.OnPreRender(EventArgs e) +45
   System.Web.UI.Control.PreRenderRecursiveInternal() +107
   System.Web.UI.Control.PreRenderRecursiveInternal() +204
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4171
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.81.0
#141956
Nov 25, 2015 11:16
Upgrade the EPiServer.UI, worked for me: http://world.episerver.com/documentation/Release-Notes/ReleaseNote/?releaseNoteId=CMS-1460
#142244
Dec 07, 2015 13:05
