What type do you store in the database? Is it a JSON serialized string? If you add a method called _setValueAttr like this, what result do you get in the console? Still undefined?
_setValueAttr: function(val) {
this._set("value", val);
window.console && console.log(val);
EDIT: I wrote this comment before I saw your answer.
I've created a custom property. After upgrade to EPiServer CMS 9.2+ (I don't remember which version), this.value inside postCreate function returns undefined.
This is the code:
Everything works fine when I try to create a page / block that contains that property. But as soon as I press the publish button (or open one of the published pages / blocks that contain that property), this.value becomes undefined.
Property value is successfully saved in the database. I can access in it from the view by calling Model.Current.MyProperty.MyField, but it's always empty in the editor.
EPiServer 9.3.3.0
Any help would be greatly appreciated!
