CMS 9 & check CurrentITransferContext
Hi all,
I've updated to CMS 9 and the line below, which I use to check that the page is not currently being imported/mirrored during page events, no longer works.
EPiServer.BaseLibrary.Context.Current["CurrentITransferContext"] != null
Does anyone know what is now the best way to check whether the current context is importing?
Many thanks,
Steven
#140907
Nov 03, 2015 16:19
It looks like this property was moved to ContextCache.
You could try to use one of two options. Use the CurrentContext static property of ExportImportBase class.
 var transferContext = EPiServer.Enterprise.ExportImportBase.CurrentContext;
or call ContextCache directly.
var transferContext = EPiServer.Framework.ContextCache.Current["CurrentITransferContext"];
The EPiServer.Enterprise.ExportImportBase.CurrentContext has the implementation that executes EPiServer.Framework.ContextCache.Current["CurrentITransferContext"]
#140920
Nov 03, 2015 20:01
Just a heads-up, mirroring is obsoleted in EPiServer 9. Please see http://world.episerver.com/documentation/Items/Upgrading/EPiServer-CMS/9/Breaking-changes/
#140924
Nov 03, 2015 22:09
Thank you Grzegorz! That's exactly what I was looking for.
@Johan, is it actually being made obsolete? I understood it that its just incompatible with previous versions, though I haven't tried it yet. I should be able to try using the updated DLL soon and will report back with any issues.
#140946
Nov 04, 2015 15:45
Ah, my fault. Yep seems to still work, just need to update the package since they have moved stuff arround.
#140947
Nov 04, 2015 15:49
